Joined: 9/4/2005 Posts: 3,539 Location: Le Muy - Var - France
GuyM wrote:Modifications in progress using the content of a box full of incomplete European tractors and various 1/50 parts sent to me from the US by Steve (member of this forum as "Exkvate 3140") [...] The set of Conrad and Joal model parts (is missing on the picture a Conrad Volvo F16 Swedish logging chassis):  After various combination trials and fitting of miscelaneous parts, I did manage to "rebuild" several new models, in addition to the Joal Volvo and Conrad Mercedes-Benz 4x2 tractors already displayed here. 1st modification complete (to be painted) a Swedish logging truck:   IVECO LD 240 E42 F/P 6x2/2 carrier with logging poles and Palfinger/Epsilon M 120Z96 forestry crane (modified Conrad model with Bemo Models parts and Conrad crane) carrying a load of 3 metres long poplar logs (homemade)  To be continued. Guy
Second rebuilt resulting in a German container carrier (to be repainted):   Mercedes-Benz 3238 L 8x4/4 carrier equipped with a 20' container chassis (modified Conrad model with Bemo and Joal elements) loaded with a Sea Box Inc. 20' maritime container (Tekno model)   Regards. Guy
Guy great customizations, can’t wait to see that log truck painted. Steve
Other combinations being progressed with parts received from the USA, a Middle-Eastern heavy haulage set and a recovery operation on German motorways.  Volvo F16-T470 6x4/2 tractor (Conrad model being modified) and ACTM S 70 320 Special Export 3-axle plant equipment transport semi-trailer (unknown brand 1/43 plastic bed being modified) carrying a Land Rover 109 Series II 4x4/2 4-wheel-drive pick-up (Corgi Toys model being modified) and a Caterpillar 834 4x4 wheeled bulldozer (CCM model)    To be continued. Guy
Last combination, far from being completed:    MAN 35-422 VFK 8x4/4 wrecker equipped with a Brechtel Masterlift Comfort F recovery body (Conrad model and body being modified) towing a MAN TGA 26-480 FDS 6x4/2 tractor (Conrad elements being modified)  Regards. Guy
Guy the parts are coming to life, all the customizing looks great. Steve
Guy is the utility box trailer a custom build. Steve
Steve, This box trailer could be seen in most small-size construction locations, being used as hand equipment storage and as change-rooms. The model is sold in kit and built form by E. Pinocheau, from Creatpshop, a French model producer having some of his models realized by N. Danchaud, from MiniCams. Link to the Creatpshop website: http://www.creatpshop.sitew.com/#Presentation.A I hope this helps. Guy
The clamshell bucket-grab,on that Renault.What is it from?That is,without doubt,the best I have seen.Does it have 'teeth'?Was it a kit?I have a grab truck,the grab on the crane is from an Atlas wheeled excavator,It is too long to hang from a crane,but you can get Conrad grabs,specifically for those types of cranes.
Guy thanks for the information, you gentleman take scale modeling to a whole new level in France. Steve
modelmaniac wrote:The clamshell bucket-grab,on that Renault.What is it from?That is,without doubt,the best I have seen.Does it have 'teeth'?Was it a kit?I have a grab truck,the grab on the crane is from an Atlas wheeled excavator,It is too long to hang from a crane,but you can get Conrad grabs,specifically for those types of cranes. modelmaniac, I first thought that the clamshell grab was a Gaz Evans item with hydraulic rams installed bottom-up but Jean-Jacques confirmed to me that it was bought as a kit from MiniCams and fitted to a Conrad knuckleboom crane. The truck itself was made by Jean-Francois from a modified Minicirque cab installed on a chassis with a homemade tipping body. I hope this helps. Guy
I want to make an eight wheel grab tipper,from Conrad trucks.Grab trucks are very popular in the U.K.There are at least ten,in my town,they are the ones I have seen!I have a two axle grab truck,much like the photo.That grab would be the perfect fit,on an 8 wheeler.So pleased you can get it,on it's own.I do know the Gaz Evans clamshell,it is way too big,for a truck crane.Hopefully Minicams have one in stock.
modelmaniac wrote:[...] That grab would be the perfect fit,on an 8 wheeler. So pleased you can get it,on it's own. I do know the Gaz Evans clamshell,it is way too big,for a truck crane. Hopefully Minicams have one in stock. modelmaniac, I'll ask Norbert from MiniCams about it and let you know. Guy
modelmaniac,
I have got a response from MiniCams: the clamshell grab is not produced anymore as its mold is out of order.
Sorry for that negative answer. Guy
GuyM wrote:modelmaniac,
Sorry for that negative answer. Guy Never mind.No doubt a suitable grab will present itself.I have a few ideas.
Guy that Mack with dump trailer is a nice looking model. Steve
