Joined: 1/11/2007 Posts: 8,690 Location: Lincolnshire
That’s cool. Didn’t know such a thing existed!
Hi Paul,
when you think of the old dirt pans drawn by track-type tractors still in use in the UK today, I never understood why there are any scrapedozers in the Kingdom. OK, bowl capacity is smaller. But cycle time is shorter since you don't have to turn around the scrapedozer. You work in shuttle traffic and its operator sits sideways, like in an underground loader.
Cheers,
Max
Very nice Mr. Scholz, thanks for posting. My understanding of the machine is that it was designed to be used in mountainous terrains where there is no room for turning around, or room to stack material. Here in the US, it would be impracticable to use as most jobs that use scrapers and Cat/Pans,dozers are usually large areas with long runs. The Cat/Pans are used in areas with heavy brown/blue clay, and srapers need a push dozer. There were two versions of the Scrape Dozer. First was a rather simple model, and the second a lot more detailed. I have not seen any for sale in quite a long time.
Not trying to hijack your post, here are a couple of pics of the earlier model.  Ken  Scraer Dozer 3 by Ken Wheeler, on Flickr"/>  Scraer Dozer 2 by Ken Wheeler, on Flickr"/>
Hi Ken,
thanks for chiming in! I have the same old NZG SR85, but minus the nice box.
Yes, the story of the scrapedozer being a mountain goat comes around from time to time. And when you see, how well they perform in Japan's mountainous landscape, it's true. Because an empty scrapedozer has a high HP/weight ratio, it usually can outclimb dozers. But actually the concept started as a military earthmover for the Wehrmacht: The idea was a machine that can cope with the soil conditions found in Central Europe under any weather conditions.
Here in Germany, fertile topsoil is protected by law. So when you want to build an industrial park, new roads, a glass house center - you have to strip the top soil and keep it for later reuse. That's a task where scrapedozers really shine and a single machine can outperform a whole team of medium-sized excavator + ADTs hands down. Mining clay also is real scrapedozer territory. The Japanese used it for farm development in the Asian rain forest with success and pioneering roads under such conditions is also something these machines can deliver convincing results. When you add ripping teeth to the bowl opening, they also can handle soft rock like shale, but they are no tuff rock machines like dozers are. And you need transport distances of 60 - 600 yards, that's perfect.
I'm pretty sure the M9 ACE was inspired by the early scrapedozers, but I'm not 100% sure about that.
Cheers, Max
Ken, both NZG scrapedozers have a fatal flaw (more apparently on the SR2001): There is no connection between the cross tube and the bowl floor. Especially the SR2001 model has a huge gap. So, during loading, the machine would simply collaps itself. As the tracks push forward the cross tube, this force has to directed directly into the cutting blade. I simply added a bent piece of 1mm brass sheet. Not perfect, but an improvement. IMG_20200705_213411 by FatCatGotHotBest regards, Max
Very good idea Max.
Hey mates, I hope your 2021 has started in a good way. Outside it's snowing, scrapedozers are in the shop for maintenance - perfect time for scale modeling! So I finally have finished another model, the MENCK M251 Rock Ripper is done. Hallelujah. This was one of these models where more mishaps came down the road as I thought they were possible. I'm really glad how it came out in the end. M251 Heavy Duty ripper dipper 027This 3 1/2 cy Menck M251 rock shovel was a dedicated ripping machine. Driven by a 2929 ci DEUTZ shunter engine of 250 HP, it produced 57 tons of bail pull via a torque converter. The 85 ton machine had a specialized ripping fork and was used in the 1950ies during dam construction in the high mountains of Switzerland. It's rear carbody was especially armored to withstand rock slides. The 1955 MACK B-8136 6x6 dump truck is the perfect match for this shovel. I have this VW bully and it is just a great referrence for the size of the MENCK: M251 Heavy Duty ripper dipper 025But for safety reasons, let's better take the MACK! (After all, the VW is from our toll authorities...) M251 Heavy Duty ripper dipper 023 M251 Heavy Duty ripper dipper 021Special attention was givin to the weathering of the bucket, as heavy ripping leads to very destinct sratches on the metal. M251 Heavy Duty ripper dipper 020After 5-6 passes, the B-8136 can depart! M251 Heavy Duty ripper dipper 022Cheers, Max
Love that bucket.  You can actually picture a face in it,LOL.Looks like a dinosaur!
Hahaha, you are absolutely right! XD And I did see it, too, because as a kid, I loved reading the children books by Richard Scarry and his power shovels had the same face:
No wonder Ma Pig,is surprised.I did not know power shovels could fly!Those Richard Scarry books bring back some old memories,I knew I had seen those characters before.
