Kerst, this has to be one of the best threads on this Forum. Your model engineering is absolutely first rate. TM
__________________________________________________________________ Tom It's pretty sad when the only modeling tool you own is a box cutter.
I can not beleive the look of this crane!!!!!!!! You are an amazing craftsman!!!! I thought i was doing good on my 64th scale trucks but I dont hold a candle to your work. This thing is awsome!!!!
Thanks for the compliments! It is great to have a forum to share progress! Last night I put it all together somehow and tried it out. I am not sure if the motors for the winches will be strong enough under load, but that will need further testing. Here is short clip: http://www.youtube.com/watch?v=CgFCE_C24eMkerst
Joined: 6/18/2007 Posts: 1,025 Location: South of the Weminuche
As said before, a "best" thread. Thanks for sharing. Another project exuding excellence in modeling. https://www.facebook.com/pages/Elis-Hobby-Diecast/803248369690387?ref=hl
Amazing vids. TFS
Amazing! What kind of control are you using for this beast? Rowan. 1:25th scale CAT 375L excavator
Joined: 1/11/2007 Posts: 9,074 Location: Lincolnshire
RI CRANEMAN wrote:Kerst, this has to be one of the best threads on this Forum. Your model engineering is absolutely first rate. TM I could not agree more. Truly a remarkable project Paul R
I did a lot of repairs and adjustments and i did another test run. that was fun! Here is a video: http://www.youtube.com/watch?v=yXltOC-IfasKerst
Your really progressing now! That is one very cool crane! TFS
Mark
Mark L.
Progress has been slow during the summer. I mainly worked on many details and little improvements everywhere. On the upper I added 3 outlets, 2 in the front and one in the back for functions like the telescoping and luffing winch for when the derrick mast is attached. I also added a couple of switches ( a toggle switch and a 3 position rotary switch) on the upper (2nd picture) to switch between functions. I have only 3 2-pole circuits coming through the slewing ring. This way i can switch between functions.   Kerst
I spent the past month figuring out the mechanism to extend the 3 boom sections. It is somehow based on the Liebherr system, one section at the time. I use a spindle, which propels 2 pins, which can hook into the bottom of each section and push it up. The whole assembly can rotate and with 3 positions available I can choose which section to extend. the motor is mounted on the side of the boom where the real one has an oil tank for the same function. Once in place the sections get locked manually.   kerst
looking really good kerst, wish i could build something like that from scratch! excellent craftsmanship! cant wait to see it all done and operating
Awesome, looks just like what liebherr uses. Can't wait to see it done
I worked on the boom quite a bit. The telescoping mechanism is ready and I did some detailing, which is almost finished. Next I will be testing the boom and getting ready for the Cabin Fever Expo in January.   Kerst
looking really good! cant wait to see it all working
Incredible Kerst! This will be one hell of a machine once it is finished!
I'm getting excited to see it work, I'm like a kids on X-mas morning waiting to open presents!!!!!
Can't wait to see more going together too Kerst, keep up the grand work!!
I love this project Kerst. I may have missed it previously but do you have a livery in mind or are you going to paint it in Liebherr yellow? Rowan. 1:25th scale CAT 375L excavator
I enjoyed the Cabin fever Expo tremendously. It gave me the chance to try everything out, play with my cranes and meet lots of great people. It was a great weekend, but afterwards I had to catch up with a few other things, so I didn't have much time for the LTM1800 till about a week ago. I started working on the counterweights. I make them out of AL, which is a bit on the light side, but the whole crane turned out a bit too heavy, so that compensates nicely and AL is easy to work with. The total weight of what you see on the picture is around 14 Lbs. It is an easy job, but time intensive with lots of (hand) sawing and lots of milling.  Kerst
