I happened to win my first Drake, a Kenworth C509, a few days ago and these mystery parts came along with it. There are no slots that I can see on the truck that these will go into. Am I missing something obvious. I am wondering if the seller actually put this in the accessory bag by mistake. I checked almost every review of the truck on cranesetc and I am none the wiser. Thanks for your help.
Joined: 6/21/2010 Posts: 154 Location: Brisbane Queensland Australia
They are not parts for a Drake Model. I would think that somewhere someone else is missing some parts..
Thanks @BAH The color does not match the truck in any manner possible. I am assuming these are sides of a ballast box or a bed. Looking at the parts again, the wider plate has notches on both ends that will slot in the shorter plates. Might as well use them for a custom made ballast box now.
D3xter wrote:Thanks @BAH The color does not match the truck in any manner possible. I am assuming these are sides of a ballast box or a bed. Looking at the parts again, the wider plate has notches on both ends that will slot in the shorter plates. Might as well use them for a custom made ballast box now. Possible off the deck on a trailer gooseneck, two sides and a front
Joined: 1/11/2007 Posts: 9,070 Location: Lincolnshire
They are off the Scheuerle Nicolas semi lowloader trailer that’s made by IMC Models.
Mystery solved. Thanks Paul. 🙏🏼
