Howdy fellers!
Today I received my first LTM 1400, and so far I have only opened the box to take a quick look without removing any component from the foam. I noticed one empty hole, and checking Ian's review (http://www.cranesetc.co.uk/library/yccreviews/790/790review.htm) turns out that's where the key ring is located at least in the standard Liebherr colors model.
I presume the key ring is not part of the Mammoet or any other business colors LTM 1400 model. Can one of you who has these models confirm this assumption? Thanks
On a very related note - even without removing the crane from the foam packaging I can tell it is of very fine quality. I tried lifting it ever so gently a couple times but gave up, will watch unboxing videos on youtube if I can find any to learn how to remove. Coming from a 1/18 diecast car collecting background I am shocked at how heavy these construction models can be!
