Concrete buckets 3D printed Options · View
eef7260
Posted: Saturday, October 07, 2017 9:12:40 AM
Did some computer scale modeling and designed some concrete buckets for 3D printing
There is a 3 Cu yard lay-down concrete bucket in 1:50 scale.
Made it available for everyone to buy at Shapeways.
It is printed in one solid piece but is also available with a separate lifting bail.
Height is 58MM , width is 44MM , depth is 42MM , loading height is 22MM
It will fit perfectly with the Manitowoc tower crane from TWH for example.
If there are questions just reply.
They can be ordered here: Concrete buckets
Eef
WP_20171007_11_57_40_Pro by eef 7260, on Flickr
WP_20171004_12_29_26_Pro by eef 7260, on Flickr
WP_20171004_12_28_58_Pro by eef 7260, on Flickr
WP_20171004_12_28_48_Pro by eef 7260, on Flickr
WP_20170930_11_14_23_Pro by eef 7260, on Flickr
***My website***Flickr American cranes group***3D printed crane parts***
eef7260
Posted: Saturday, October 07, 2017 9:25:31 AM
Also did some European style buckets in 1:50 scale.
These are available in 3 sizes 750 Liters , 1250 Liters and 2000 Liters
And did them in others scales as well , 1:87 and 1:160
750L has a round lifting bail and the bigger ones square lifting bail.
Pictures are from the smallest , the 750 L
Also available here : Concrete buckets
1A by eef 7260, on Flickr
4A by eef 7260, on Flickr
The 750 L next an unpainted 1250L
3A by eef 7260, on Flickr
3 types , 3 Cu yard lay-down , 750 L and the 1250L
mariot
Posted: Sunday, October 08, 2017 5:01:04 PM
The beauty of 3D printing. Nice to see the Gar Bro lay-down style bucket finally available. Have already ordered the version with separate lifting bail. Now I don't have to scratchbuild these style buckets anymore!! Thanks eef7260!!
eef7260
Posted: Sunday, October 08, 2017 5:21:55 PM
Hi Mario
You are welcome hope you like it.
Have ever been working with the 3D printed material ? ( white strong and flexible )
It's not easiest material to spray paint but it can be done , look at the pictures.
But it is the cheapest and strongest .
Difficulty is in the fact that its made from tiny melted together par ticals.
This has the characteristic that it sort of soaks your primer.
So the first layer of primer has to be done much thicker than you used to.
Start spraying in layers and go on till you got the whole part sort of shiny wet.
Let it dry , do some sanding and primer again , again some drying and some sanding.
Now put on the definite layer of paint.
Key is make thicker layers but do not loose to much detail.
Ps the good part of this material is it can resist paint thinner so you can start over again Teeth
Hope to see the results here one day
Is the 3 Cu yard a good choice ?? or are other sizes more interesting ??
Eef
mariot
Posted: Sunday, October 08, 2017 8:09:52 PM
Eef,
As far as the color of the bucket is concerned, I don't mind it left in white, more likely, I will "get it dirty"; in other words, weather it to look as if used. I probably will add the "IN" and "OUT" that is usually painted on the 1:1 buckets when two are used behind a concrete truck.
The 3 yard size is perfect. The 3 cubic yard size is the size I am used to seeing; a larger one built by Gar Bro was a 6 cubic yard version used when the foundation for the new One World Trade Center was under construction. According to their literature, the largest is a 10 cubic yard model.
An extended chute lay-down bucket of 2 or 3 yard capacity would be a nice addition. I'd like to post a picture of one I recently scratchbuilt for a diorama, but I am unable to post pictures anymore via photobucket Sad
Mario T
eef7260
Posted: Monday, October 09, 2017 2:31:59 PM
Hi Mario
Can always have a look and give it a try.
Yep they do not allow forum links anymore , Go for an flickr account , this works well ( at least for now Teeth )
Eef
mariot
Posted: Tuesday, October 10, 2017 8:16:01 PM
RMS Models
Posted: Tuesday, October 10, 2017 8:19:30 PM
mariot
Posted: Saturday, October 14, 2017 5:46:31 PM
Eef,
I hope this works. Here are the photos of the rear of the extended-chute concrete bucket. It is different from the standard bucket. In addition, the linkage to open the chute is also different. Were you working from the original GarBro drawings when you created the standard buckets?
Pictures.
IMG_2204 by Mario Torres, on Flickr
IMG_2203 by Mario Torres, on Flickr
IMG_1117 by Mario Torres, on Flickr
Thank you for instructing me how to post via Flickr!
eef7260
Posted: Sunday, October 15, 2017 6:33:30 AM
Hi Mario
Good to see uploading pictures works for you.
Work in progress , in a week or so it will be there.
I grab my info everywhere from the net , as much as i can find , even found some pictures from an old rusty one on ebay Teeth
Do you have pictures of the rear from the real bucket ?
Eef
Image1 by eef 7260, on Flickr
