Some impressions of the Liebherr crane days on last Saturday in Ehingen: More information and huge picture gallery in our corporate blog: http://www.equipmenthandbooks.com/2012/06/liebherr-lr-13000-on-crane-days/
Greetings Carsten Customized load chart books | Crane CAD blocks | Crane specifications
sweet, is the lr13000 equivalent to the manitowc 31000?
Nothing runs like a deere with a cat on its back but the link belt ate both of them
I haven't seen the 31000 live yet, but I guess it is more equivalent to the LR 11350
What's the deal with the gray primer look? I thought they were yellow/white? Daily Diesel Dose.com| All Ready Mix.com | Plowsite DOT Thread | If your only contribution is complaining, please don't contribute!
It's a primer look because it is primer, they are painted in the grey before the actual color scheme. Super photos Carsten Heavy Cranes
Joined: 11/10/2010 Posts: 452 Location: Borden SK Canada
Dan85 wrote:What's the deal with the gray primer look? I thought they were yellow/white? this is because the crane could be either in a test proses of it is waiting for a buyer. Because the LR13000 for mammoet is all ready red and going to America.
Mammoet- Size does Matter. Dafgek
No, the 31000 is the equivalent as the LR 13000, both are 3000t cranes
great pictures, i cant wait to see the Eisele LTM 1750 painted up. The LTR 1220 looks pretty interesting too, seems to sit pretty low with a very wide track base
DeWoc19 wrote:No, the 31000 is the equivalent as the LR 13000, both are 3000t cranes Ok, I just compared the size of the crane and it appeared to be more a 11350.
Casi wrote:DeWoc19 wrote:No, the 31000 is the equivalent as the LR 13000, both are 3000t cranes Ok, I just compared the size of the crane and it appeared to be more a 11350. i understand, i have seen the 31000 when it was first unveiled and its HUGE! it looks every bit just as big as the LR 13000 even though i have never seen the LR. But yeah, they are both 3000t cranes
The 31 is actually smaller than the 13000, the 31 is 2,526 ton capacity crane while the 13000 is 3000 tons
cranedude07 wrote:The 31 is actually smaller than the 13000, the 31 is 2,526 ton capacity crane while the 13000 is 3000 tons
cranedude07 wrote:The 31 is actually smaller than the 13000, the 31 is 2,526 ton capacity crane while the 13000 is 3000 tons the 13000 is 3000t in metric, its 3300 short tons..... thats 25% bigger 31000 is tiny  Liebherr eats Manitowoc cranes for breakfast
DeWoc19 wrote:cranedude07 wrote:The 31 is actually smaller than the 13000, the 31 is 2,526 ton capacity crane while the 13000 is 3000 tons the 13000 is 3000t in metric, its 3300 short tons..... thats 25% bigger 31000 is tiny  Liebherr eats Manitowoc cranes for breakfast Dont for get it eats Terex/Demag cranes for dinner
DeWoc19 wrote:cranedude07 wrote:The 31 is actually smaller than the 13000, the 31 is 2,526 ton capacity crane while the 13000 is 3000 tons the 13000 is 3000t in metric, its 3300 short tons..... thats 25% bigger 31000 is tiny  Liebherr eats Manitowoc cranes for breakfast Nope! the 31000 is 2300 metric ton crane, which means it's 2535 US tons.
And don't forget that Terex Demag have had a 3200t capacity crane on the Market for years now. Heavy Cranes
Superb photos and information Carsten so thank you.
I like the way the two ladies are casually sitting under the tracks of the 13000!.
Jack. wrote:And don't forget that Terex Demag have had a 3200t capacity crane on the Market for years now. I'd rather a paper weight than a wind chime
Dewoc is right, according to Liebherr's website just now the 13000 has a 6,613,800lb maximum lifting capacity or 3306.9 short tons. The 13000 is the largest crawler crane on the market today unless you believe Sany. The 31000 is, however, the most advanced crawler crane in the world and one of the largest with a 2,535T capacity. I know Liebherr fans may disagree as Liebherr has some high-tech stuff, but the 13000 is just a bigger version of a 20+ year old configuration. The 31000 is going in a new direction....at least I hope it goes somewhere....
The fundamental aim....is to do everything that is attempted in a first-class way." -Pierre S. Dupont
the 31000 should have a better advantage over the 13000, as the 31s CW tray never touches the ground, thus resulting in less ground preparation, the 13000s superlift tray, has to sit on the ground while not in operation, and the 31s ground bearing pressure, with a load, is equal to a m777 or 186psi or 26,784psf! plus the 31 can travel at full capacity! dont know why i said 2,526 tons  i know better than that! can also lift 1,534 tons with fixed jib and 1,102 tons with luffing jib!
Joined: 9/16/2007 Posts: 2,707 Location: Staten Island, New York
Anyone know how you transport those massive concrete counterweights on the LR? They look larger than what a traditional trailer can haul.
-Vinny http://www.heavytruckphotos.com/
