Joined: 9/4/2005 Posts: 3,544 Location: Le Muy - Var - France
The IMC Mercedes-Benz tractor in Tii colors (at that time Scheuerle, Nicolas and Kamag):    - Mercedes-Benz Arocs 3351 LS 6x4/2 tractor and Nicolas Euroflex 3 lowboy semi-trailer fitted with a 3-axle low bed with lifting front ramp and a winch (IMC models), - Demag DF 120C tracked finisher of 18 tonnes (NZG model),  Regards. Guy
Joined: 6/18/2003 Posts: 2,254 Location: Charlotte, North Carolina
Good looking rig there Guy. I like loading ramps. Craig
In Switzerland:  Saurer S4C-45 4x2/2 dropside truck carrying 17 beer barrels: Vitesse model(*),    Note (*):the original model produced by Vitesse (Portugal) looks exactly like Saurer and White Corgi later models (UK/China) or like the Saurer S4C Tek-Hoby 1/50 unit (Switzerland). Regards. Guy
SAVIEM Goelette van, built by Jean-Jacques from a Minicirque kit:     Regards. Guy
Richelmi Renault 4x2 tractor and 6x4 tippers (all kits by Jean-Jacques):     Regards. Guy
Still with Richelmi, a Renault R truck built by Jean-Jacques (from a Conrad ex-MAN TGS-M):     Regards. Guy
The Richelmi truck during the construction phase:  Regards. Guy
  Mercedes-Benz Antos 2543 L 6x2/2 truck fitted with a container or swap body chassis and loaded with a 7.45 metre Wecon Grand Duke II tautliner swap body (NZG models),   Regards. Guy
   Hanomag F76 4x2/2 light truck fitted with a tipping body (RW Modell model),  Regards. Guy
  - left :Dynapac CA 25-I articulated 3x2 compactor with front roller and rear wheels (Arpra model), - right: Dynapac CA 25-II articulated 3x2 compactor fitted with a front roller and rear wheels (Arpra model). To be continued. Guy
 Scania R143M-400 6x2/2 truck fitted with a box body and 1+2-axle unknown brand box body drawbar trailer (WSI models),    Regards. Guy
  ERF EC11.46MT 6x2/4 tractor and Crane-Fruehauf reefer box with low bed 3-axle semi-trailer (modified(*) Corgi models),   Notes (*): the tractor had its 5th wheel modified to accept other semi-trailers. the semi received a king pin compatible with tractor's 5th wheel. Regards. Guy
In the USA and in a 1/48 scale, 2 railroad companies distribution trucks:   - left: - Mack RB 688SX 6x4/2 truck fitted with a Morgan distribution body (modified(*) K-Line model) with Moffett-Kooi M5 20.3 3x1/1 piggy-back forklift (modified(*) Corgi modiel), - right: Mack RB 688S 6x4/2 truck equipped with a Morgan distribution body (K-Line model). Notes (*): a Mack truck had received a rear forklift support, from Corgi origin. The Moffett-Kooi forklift (damaged) was repaired and had its ROPS protection removed. To be continued. Guy
