3J&G 1:50 models collection. Options · View
Quinella
Posted: Tuesday, July 15, 2025 11:48:15 AM
Guy: You are right about avoiding license fees. But these are actually pretty good quality for the money. You can buy one sometimes as low as $12.00 give or take. The tank trailer is cool. And the wheels ae super. I probably have purchased three dozen of thses oveer the years. Craig
GuyM
Posted: Saturday, July 19, 2025 3:09:24 AM
Craig,
Many thanks for the info on the Citgo model: they are pretty rare (and more costly) on that side of the pond.
Another Mack (fully licensed):
Mack Anthem 64T 6X4/2 tractor and Trailmobile ?????45 2-axle box semi-trailer (First Gear models),
Regards.
Guy
GuyM
Posted: Wednesday, July 23, 2025 3:00:55 AM
- left: Minitrucks cab kit on a Conrad tipper chassis,
- right: Minitrucks kit.
Both models are built by Jean-Jacques.
To be continued.
Guy
GuyM
Posted: Wednesday, July 23, 2025 3:05:15 AM
The Magirus-Deutz tipper:
To be continued.
Guy
GuyM
Posted: Wednesday, July 23, 2025 3:09:19 AM
The Hanomag-Henschel tipper:
Regards.
Guy
Quinella
Posted: Wednesday, July 23, 2025 3:26:04 PM
Guy: The Mack Vision trucks are terrific. I used to have maybe a dozen. The quality is great. The various logos were great. I think they are 1:54 scale. As I remember, First Gear made Freightliner versions too. thanks,Craig
GuyM
Posted: Thursday, July 24, 2025 4:23:19 AM
Craig,
Sorry to seem to contradict you but the Vision box semi-trailer could just be a 96'' wide 45' long Trailmobile trailer in a 1/50 scale (2.44 meters wide, 13.72 meters long), while First Gear also produce unknown brand 102'' (2.59m) wide 53' (15.6m) long units in the same scale.
I agree with you, the Vision box trailer looks smaller than its counterpart in that case.
I hope it helps.
Guy
Quinella
Posted: Thursday, July 24, 2025 10:54:25 AM
Guy: Google First Gear 1/54 Mack Vision trucks and you will see some of the various trucks they made. Craig
GuyM
Posted: Thursday, July 24, 2025 1:41:21 PM
Craig,
You are right about the Mack First Gear scale: I recently found these 2 pictures on e...:
I hope it helps.
Guy
GuyM
Posted: Sunday, July 27, 2025 3:17:13 AM
Soil removal by Jean-Jacques.
The Magirus-Deutz tipper (Minitrucks cab on Conrad tipping chassis) being loaded alongside a Berliet tractor and its tipping semi-trailer (Minitrucks kits). The cable excavator is a 1/50 NZG Menck & Hambrock model:
Regards.
Guy
GuyM
Posted: Thursday, July 31, 2025 3:29:24 AM
Willeme logging truck (Minitrucks kits), by Jean-Jacques:
Regards.
Guy
Pascal73
Posted: Saturday, August 02, 2025 3:51:43 AM
GuyM wrote:
The same crane in its roadable version. Shield Bantam T35 lattice crane with grab on a White WC22 Mustang 6x4/2 truck, roughly changed into a crane carrier at minimum cost (SpecCast model):
Regards.
Guy
Guy, est-ce une version du commerce ou une version faite maison? Merci de ta réponse.
www.ec1000.net
GuyM
Posted: Saturday, August 02, 2025 10:49:27 AM
Pascal,
Ce modèle SpecCast est intégralement du commerce, sans modification de ma part.
This SpecCast model came direct from the shop, I didn't change anything to it.
Regards.
Guy
GuyM
Posted: Monday, August 04, 2025 3:16:17 AM
Other Willeme transports:
The Willeme truck, together with a Berliet unit (Minitrucks kit):
The Berliet truck, converted into a logging combination:
Regards.
Guy
GuyM
Posted: Friday, August 08, 2025 3:25:20 AM
- Left: Renault R 2087 4x4/2 light truck, fitted with a Guinard tank/fire pump (Solido model),
- right: Renault R2087 4x4/2 light truck with a sheeted dropside body (Verem model to be modified*)), towing a modified Ben Hur Mfg G 527 1-axle tank trailer (Verem model).
Note (*): transmissions/axles to be modified.
To be continued.
Guy
GuyM
Posted: Friday, August 08, 2025 3:28:23 AM
To be continued.
Guy
GuyM
Posted: Friday, August 08, 2025 3:33:27 AM
Regards.
Guy
GuyM
Posted: Tuesday, August 12, 2025 3:18:53 AM
In Europe, beginning of the nineties, sleeping compartment over the cab trucks began to appear, aimed at optimizing the overall length of heavy vehicles. Late nineties, a modification in European rules related to useful boxes lengths only (cabs excluded) led to the extinction of such practices:
DAF FAS95-360 Ati 6x2/4 truck fitted with a bunk-over-the-cab device and a large volume Kögel box (modified Tekno model(*)) and its matching Kögel 2-axle close-coupling large volume box trailer (Tekno model),
Note (*): one of the Kögel box door (fragile) on the truck was glued in closed position.
Regards
Guy
GuyM
Posted: Saturday, August 16, 2025 2:54:08 AM
Multiple winner of the "24h du Mans" endurance car race, H. Pescarolo created his own car race team, Pescarolo Sport, which will be finally bought-out in July 2010, following some financial problems:
Scania R620 4x2/2 tractor and Krone ???? 3-axle semi-trailer upgraded into a race assistance box unit by the French truck body builder Toutenkamion (?) (modified(*) Universal Hobbies models),
Note (*): tractor's fifth wheel and semi-trailer's king pin were modified to accept WSI models.
Link to the Wikipedia article dedicated to H. Pescarolo (in French, sorry): https://fr.wikipedia.org/wiki/Henri_Pescarolo .
Regards.
Guy
GuyM
Posted: Wednesday, August 20, 2025 3:30:06 AM
In France still, with a temperature-controlled transport:
Renault Trucks T 520.25 6x2/4 tractor and D Tec Flexitrailer HD S Line container carrier 3-axle extendable chassis semi-trailer, loaded with an unknown manufacturer 40ft reefer container (WSI models and load),
Regards.
Guy
