Joined: 9/4/2005 Posts: 3,531 Location: Le Muy - Var - France
  Mercedes-Benz Arocs 4163 SLT 2.3 8x6/4 tractor (WSI model) and Nooteboom Euro-PX 126-35(ICP)(V) modular semi-trailer with 5-line extendable ultra-low bed and 3-line integrated dolly (modified WSI model) carrying a 67.68 tonnes Komatsu D375A-5 bulldozer (First Gear model),   To be continued. Guy
   MAN TGA 41-530 DFVD 8x4/4 tractor and Goldhofer SPZ-DL 6 6-axle flatbed ballast carrier semi-trailer (Conrad models) loaded with 49.3 tonnes Richter Maschinenteile AG steel plates (Ladeguter Bauer modified load(*)),  Note*: the load was originally part of a Ladeguter Bauer assembly made of 3 scale O loads: two of 49.3 tonnes and one of 102 tonnes (as per my calculation with 7.85 tonnes/m3 steel specific gravity). The unique support frame was removed and replaced here by 3 wooden beams. Regards. Guy
Other Ladeguter Bauer element:  Scania/Läxä R420 8x4/4 tractor (modified(*) NZG model) and Scheuerle InterCombi 50 L2/10 10-line lowbed modular semi-trailer (WSI model), loaded with nearly 17 tonnes of Scheuerle ultra-low vessel-bed elements (WSI model) and with 2 Richter Maschineneile AG steel plates of 51 tonnes each (modified(*) Ladeguter Bauer elements),   Note (*): lmodifications were as follows:: - NZG tractor: its fifth wheel was replaced by a modified WSI one and cab decals removed, - WSI semi-trailer: the vessel beams elements were removed from the 4-bed-6-line origin semi-trailer, - load: the 102 tonnes load was part of a Ladeguter Bauer assembly built for O train models: its original support was removed and replaced by 3 wooden beams. To be continued. Guy
  MAN TGX 18-680 BLS 4x2/2 tractor (modified(*) Joal model) and Faymonville MAX100 N-3A-9.30 (U) 3-axle lowboy (modified(*) Cavallino model) carrying a MAN TGS 26 440 BL 6x2/2 truck fitted with an Esterer tank (Siku model being modified(*)),   Note (*): modifications were as follows: - tractor:Joal fifth wheel was removed and its chassis milled, a WSI-type 5th wheel was installed instead. Two flashing lights were added on the roof, - semi-trailer: the Cavallino connecting pin was replaced by a WSI-type one, - tanker truck: the Siku wheels were changed to Tekno ones; the pipe stopping mechanism replaced by a small washer, the emptying system at the back plugged. A third manhole is to be added on the top of the tanker. Regards. Guy
Joined: 6/18/2003 Posts: 2,250 Location: Charlotte, North Carolina
Guy: The Scania rig is over the top good looking. It could rank as one of my favorites from you fellows. Craig
Craig,
Many thanks for your positive comments.
Guy
   Scania P380 6x2/2 with top sleeper and Oakley Supremacy body made of slide-out features accommodation and a 7-stall horsebox (Tekno model),  Regards. Guy
 Volvo FH4-T560 6x2/2 tractor (WSI model) and Burgers BAO-15-27 GZ 3-axle double floor box semi-trailer with a Dhollandia DHSH hydraulic tailgate (modified(*) Tekno model),    Note (*): the Tekno model had its coupling pin removed and replaced by a WSI-type one and the "Scania" decals ripped-off, this model being specifically produced for the Swedish truck manufacturer (see page 8: https://www.scania.com/content/dam/scanianoe/market/tw/experience-scania/merchandise/New_Model_Catalogue_2019.pdf ). Regards. Guy
Mercedes-Benz LAK fitted with a Meiller tipping body (Conrad model):     Regards. Guy
The Conrad Mercedes-Benz with 2 Siku lighter tippers. The Poclain excavator (with its cab) is also a Conrad product:     Regards. Guy
Poclain excavator (Conrad model):    Mercedes-Benz tippers LAK (Conrad model) and LK (2 Siku models):  Regards. Guy
  Scania 164G-T580 8x4/4 tractor with removable HFR rear additional axle (WSI model) and Scheuerle InterCombi 50L2 2+4 modular semi-trailer with 4-line rear flatbed plus 2-line integrated front dolly (modified(*) WSI model) loaded with a 70 tonnes Vestas V162*5.6/6.0 windmill nacelle (IMC load),   Note (*): both extendable beams have been removed from the modular semi-trailer and their widening supports connected together. To be continued. Guy
   Berliet GBC 8KT 6x6/2 truck fitted with a Camiva FIPD box intervening in case of dangerous goods (Solido model),  As a bonus, the GBC 8KT/Camiva FIPD from Rouen (Seine Maritime) Fire Brigade:  Regards. Guy
Guy: the Vestas rig is good looking. Is it a twin steer? If not, does the second axle lift? Craig
Quinella wrote:Guy: the Vestas rig is good looking. Is it a twin steer? If not, does the second axle lift? Craig Craig, The Torben Rafn Scania is a 8x4 (twin steer) but, as far as I know, its second axle does not lift. The tractor can be seen below:  I hope it helps. Guy
  O&K L35B 4x4 wheeled loader (Auto Russia(*) model),   Note (*): I have very few information on that modeller; he only built in a 1/50 scale a few Krupp telescopic cranes and an O&K mining shovel plus some O&K wheeled loaders (nicely modeled, as far as I know). Regards. Guy
 Ford F550 CC 4x4/2 pick-up truck with skate body (Menards(*) model), carrying 6 Goodyear 50X31.00-26HP plant equipment tires on a wooden support (modified Menards load(*)),    Notes (*): Menards is an US large stores group, building in 1/48 scale some items to be carried on O trains (1/48 in USA), which are sold in these stores as well. The Goodyear tires are resting on a homemade wooden support, allowing them to be carried in 'normal" position. Regards. Guy
