Joined: 9/4/2005 Posts: 3,402 Location: Le Muy - Var - France
  Mercedes-Benz Arocs 4163 SLT 2.3 8x6/4 tractor (WSI model) and Nooteboom Euro-PX 126-35(ICP)(V) modular semi-trailer with 5-line extendable ultra-low bed and 3-line integrated dolly (modified WSI model) carrying a 67.68 tonnes Komatsu D375A-5 bulldozer (First Gear model),   To be continued. Guy
   MAN TGA 41-530 DFVD 8x4/4 tractor and Goldhofer SPZ-DL 6 6-axle flatbed ballast carrier semi-trailer (Conrad models) loaded with 49.3 tonnes Richter Maschinenteile AG steel plates (Ladeguter Bauer modified load(*)),  Note*: the load was originally part of a Ladeguter Bauer assembly made of 3 scale O loads: two of 49.3 tonnes and one of 102 tonnes (as per my calculation with 7.85 tonnes/m3 steel specific gravity). The unique support frame was removed and replaced here by 3 wooden beams. Regards. Guy
Other Ladeguter Bauer element:  Scania/Läxä R420 8x4/4 tractor (modified(*) NZG model) and Scheuerle InterCombi 50 L2/10 10-line lowbed modular semi-trailer (WSI model), loaded with nearly 17 tonnes of Scheuerle ultra-low vessel-bed elements (WSI model) and with 2 Richter Maschineneile AG steel plates of 51 tonnes each (modified(*) Ladeguter Bauer elements),   Note (*): lmodifications were as follows:: - NZG tractor: its fifth wheel was replaced by a modified WSI one and cab decals removed, - WSI semi-trailer: the vessel beams elements were removed from the 4-bed-6-line origin semi-trailer, - load: the 102 tonnes load was part of a Ladeguter Bauer assembly built for O train models: its original support was removed and replaced by 3 wooden beams. To be continued. Guy
  MAN TGX 18-680 BLS 4x2/2 tractor (modified(*) Joal model) and Faymonville MAX100 N-3A-9.30 (U) 3-axle lowboy (modified(*) Cavallino model) carrying a MAN TGS 26 440 BL 6x2/2 truck fitted with an Esterer tank (Siku model being modified(*)),   Note (*): modifications were as follows: - tractor:Joal fifth wheel was removed and its chassis milled, a WSI-type 5th wheel was installed instead. Two flashing lights were added on the roof, - semi-trailer: the Cavallino connecting pin was replaced by a WSI-type one, - tanker truck: the Siku wheels were changed to Tekno ones; the pipe stopping mechanism replaced by a small washer, the emptying system at the back plugged. A third manhole is to be added on the top of the tanker. Regards. Guy
Joined: 6/18/2003 Posts: 2,205 Location: Charlotte, North Carolina
Guy: The Scania rig is over the top good looking. It could rank as one of my favorites from you fellows. Craig
Craig,
Many thanks for your positive comments.
Guy
   Scania P380 6x2/2 with top sleeper and Oakley Supremacy body made of slide-out features accommodation and a 7-stall horsebox (Tekno model),  Regards. Guy
 Volvo FH4-T560 6x2/2 tractor (WSI model) and Burgers BAO-15-27 GZ 3-axle double floor box semi-trailer with a Dhollandia DHSH hydraulic tailgate (modified(*) Tekno model),    Note (*): the Tekno model had its coupling pin removed and replaced by a WSI-type one and the "Scania" decals ripped-off, this model being specifically produced for the Swedish truck manufacturer (see page 8: https://www.scania.com/content/dam/scanianoe/market/tw/experience-scania/merchandise/New_Model_Catalogue_2019.pdf ). Regards. Guy
Mercedes-Benz LAK fitted with a Meiller tipping body (Conrad model):     Regards. Guy
The Conrad Mercedes-Benz with 2 Siku lighter tippers. The Poclain excavator (with its cab) is also a Conrad product:     Regards. Guy
