HHR Vintage Talbert lowboy trailer Options · View
cat20
Posted: Friday, August 30, 2024 12:42:06 PM
Scheduled for end of 2024.
Does anyone know the detach system on these old trailers? Pony motor, wet kit, winch, or?
https://www.facebook.com/photo/?fbid=381044718370674&set=a.162313426910472
Pullshovel52
Posted: Friday, August 30, 2024 2:48:35 PM
Rank: Newbie
When a Talbert cable neck trailer was to be unloaded, the driver would release the fifth wheel, then drove the tractor ahead slowly. The trailer slid down a ramp on the tractor, immediately behind the fifth wheel. The gooseneck then was secured to the tractor by a pair of steel stops, which fit into holes on the ramps. Cable from the tractor's winch was secured to the A-frame on the gooseneck, and the driver then pulled away from the trailer. As one old-timer said to me, pretty slick.
kcmtoys
Posted: Saturday, August 31, 2024 1:03:36 PM
Pullshovel 52 "nailed it". Here is a picture from a Talbert brochure. We use to use 2 Dayton wheel clamps (second picture) with bolts in the rails to hold the neck to lift. hold, and lower the neck.Teeth Useually you would just back under the neck when loaded. But if you had a heavy machine there was a D ring on the front of the neck and you used the winch to pull the neck back up. Sometimes the tractor would pull a "wheelie"...Whistle
Talbert Cable neck 2 by Ken Wheeler, on Flickr"/>
Dayton wheel clamp wedge by Ken Wheeler, on Flickr"/>
cat20
Posted: Saturday, August 31, 2024 2:00:02 PM
Thank you both!
Very cool. Now I can see how it works.
