WSI. Kenworth C500B Options · View
Claus
Posted: Tuesday, November 24, 2020 11:37:59 PM
Has anybody tried pairing the WSI Kenworth with the DM 2X3X2 lowboy? Can anybody share a photo or two of that combo? I don’t have either but am considering both. Thanks.
kcmtoys
Posted: Wednesday, November 25, 2020 3:38:41 PM
I will get some posted later Claus.
Claus
Posted: Wednesday, November 25, 2020 3:41:26 PM
You’re awesome Ken, thank you!
kcmtoys
Posted: Thursday, November 26, 2020 11:36:29 PM
Here you go Claus. You will need to drill a larger hole in the 5th wheel for the king pin. If you have the two axle jeep, both sets of wheels are on the ground. If you make a three axle jeep, the front axle is a just a hair high.Whistle Shhh
100_2233 by Ken Wheeler, on Flickr"/>
100_2234 by Ken Wheeler, on Flickr"/>
100_2235 by Ken Wheeler, on Flickr"/>
100_2236 by Ken Wheeler, on Flickr"/>
Claus
Posted: Thursday, November 26, 2020 11:39:57 PM
Thank you very much Ken!! Not easy to get all of that in the pic. Now I know what to ask Mrs Claus for for Christmas!
Claus
Posted: Friday, November 27, 2020 12:06:22 AM
Ken you need a black DM lowboy set for that rig!
kcmtoys
Posted: Friday, November 27, 2020 3:36:59 AM
Not a bad idea Claus, I have one. Here is what it is usually hooked to. Whistle
96153735_2875183722599634_8385834125436649472_n by Ken Wheeler, on Flickr"/>
Claus
Posted: Friday, December 11, 2020 11:37:54 PM
Ken would it be possible to make a new trailer kingpin vs drilling the fifth wheel out on the truck?
Claus
Posted: Friday, December 11, 2020 11:41:47 PM
Just noticed the Jersey barriers in your ballast box, nice touch!
kcmtoys
Posted: Saturday, December 12, 2020 4:47:21 PM
You would have to cut the old one off the bottom of the jeep neck, drill it, and install a new king pin. If you drill the 5th wheel, you only need a little touch up paint around the hole. If the hole is too big for other trailers, I have inserted a small brass tubing sleeve in there for the smaller pin. In the above pictures, I slid the 5th wheel back and have the jeep neck pin "sitting" in front of the 5th wheel, and you can't notice it. Whistle
kcmtoys
Posted: Saturday, December 12, 2020 4:49:39 PM
Thanks Claus. I have seen quite a few around here that use Jersey Wall or concrete blocks. That way, you can add a little more if you need it!
wildpig1234
Posted: Thursday, December 17, 2020 1:00:57 PM
I like at least 3 rear axles on my tractor Smiley. Only two is too little.
kcmtoys
Posted: Saturday, December 19, 2020 2:26:40 PM
The KW C500 from Sword and WSI only comes in a tandem axle configuration. You just need to use a jeep with a trailer.
