Euclid R-62 dump truck in 1/24 Options · View
kerst
Posted: Tuesday, March 05, 2019 12:45:24 AM
Jamiescotland
Posted: Wednesday, March 06, 2019 6:30:07 AM
AAAAAAAAAAAAAAAAAAAAAAAAAA-MAZING!!!!! Can you build two? One to leave bare metal and one to paint?
kerst
Posted: Friday, April 12, 2019 5:34:24 PM
Small update on the Euc.
I didn’t have much time lately for a variety of reasons, including a bad cold that kept on coming back.
But I managed to get the drive shafts done. I installed 2 temporary gear motors and that gave me the opportunity to test the truck and worked out some problems in the drive axles.
Kerst
modelmaniac
Posted: Friday, April 12, 2019 11:01:37 PM
Looks really,really goodApplause Love them wheels!
Exkvate3140
Posted: Friday, April 12, 2019 11:23:56 PM
Kerst that looks fantastic
Steve
Mark Bridle
Posted: Tuesday, April 16, 2019 6:27:54 AM
Given that the rear axles are not driven off a common drive, how are you going to match the axle speeds?
SDBOB
Posted: Tuesday, April 16, 2019 9:38:03 AM
Wow very nice detail. Planning, and plans,I cant imagine!
kerst
Posted: Tuesday, April 16, 2019 2:41:12 PM
This is a temporary setup. It will have one motor with a 4-speed gearbox.
Kerst
kerst
Posted: Tuesday, September 24, 2019 11:07:07 PM
I did some work on the Euc. I installed a Mabuchi 555 12V DC Motor, which seems to have sufficient power for this truck. And I built a temporary reduction box, so that I can drive it around and get a sense of the speeds. later I will build the final gearbox.
I tested the Euc in the dirt and took some videos:
https://youtu.be/V9AssoKzzBI
https://youtu.be/zraLPbm_xeM
Kerst
Quinella
Posted: Tuesday, September 24, 2019 11:11:49 PM
I would have given up the "left one" to be as talented as you. That is so fantastic. Keep up the pictures and content for us. CAW
Exkvate3140
Posted: Wednesday, September 25, 2019 11:08:47 PM
Kerst that is fantastic as the Q said very talented. Can not wait to see that monster finished and painted.
Steve
kerst
Posted: Friday, December 13, 2019 11:44:40 AM
I tried a simple mechanism for the tipping. It is basically a geared motor with a small winch pulling a lever, which does the tipping. This is the first try and I managed to lift it with a 11 lbs load. Not bad. Now I can work out the details.
Here a video: https://youtu.be/CMy56WsefUk
Kerst
SDBOB
Posted: Friday, December 13, 2019 1:25:27 PM
Impressive work. Thanks for sharing.
Exkvate3140
Posted: Friday, December 13, 2019 10:45:38 PM
Very nice work.
Steve
randy krieg
Posted: Saturday, December 14, 2019 1:37:27 AM
AWESOME work! Thanks for sharing.
Best Regards, Randy
kerst
Posted: Monday, January 20, 2020 6:46:12 PM
I had the chance to try it out at the Cabin Fever Expo in Lebanon, PA.
Here a video of the Euc in action:
https://youtu.be/0ddt3ukXhLI
Kerst
Exkvate3140
Posted: Monday, January 20, 2020 8:12:54 PM
That’s incredible, I can’t wait to see that that in Euclid green. Great action video of that monster.
Steve
Weserhutte
Posted: Monday, January 20, 2020 9:06:17 PM
Not the dump mechanism I was expecting to see, but it's still brilliant engineering. Bravo Kerst!
kerst
Posted: Saturday, March 07, 2020 9:28:42 PM
I have been working on the power-shift transmission. This is an experiment and needed some proper preparation, including calculating ratios, making accurate drawings, etc. Quite the challenge!
The Clark series 6000 is the example.
I omitted the forward/reverse clutches. An electric switch can take care of that and it saves space.
I use leather as clutch material.
The middle shaft on the left is the input shaft and I still need to figure out how to connect that to the motor, an 540 CRAWLER BRUSHED MOTOR 80T.
I am still making all the components and I am not sure if it all will work.
Making the frame demanded a lot of accuracy. My Southbend was up to it! I did a lot of measuring at every stage to make sure things will fit OK.
So far so good. I plan to control the clutches with 2 servos. W'll see how that works out!
Kerst
EliMax
Posted: Monday, March 09, 2020 12:13:39 AM
Amazing work. I love seeing how you meet your challenges.
https://www.facebook.com/pages/Elis-Hobby-Diecast/803248369690387?ref=hl
