Now that is some load for a test-lift !
Chet
Looking good! Certainly very stable!
Finally I managed to paint the Derrick tray and counterweights. Here are some pictures: Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Awesome work Kerst .
I got inspired by this crane again and started to add the jib. There is a fixed jib and a luffing jib available and they share many basic parts. So I started to make some of the parts that can be used for both. initially i will make the fixed jib and later the more complicated luffing jib. Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Great to see this project back again!
Looks great! I'm glad you are still accessorizing this model, and thanks for sharing. Do you refer to the YCC model at all as part of your research? I'm pretty sure you began this before the YCC came out, and I know that you do all your own research for your other models. Just curious.
Your work is outstanding. Steve
Thank you for the kind remarks! I made some good progress these past weeks. Next is a 7 meter insert. Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Very nice Steve
Joined: 6/21/2010 Posts: 308 Location: Odense, Denmark
awesome! long time ago since ive been here on the forum, and luckely i saw this post, i remember it as it was yesterday, the ltm 1800 is still one of my fav cranes :D
I decided to make the luffing jib as well and I am almost done. Only the pendants need to be made. Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Oustanding!
Great craftsmanship. Steve
Beautiful work!
Finally I put it all together. Getting all the bits together took quite a bit of time and I had to make a few adjustments to the winch for the luffing jib. yesterday was the day and it worked nicely. I am fairly pleased with the result and how easily the crane handled the luffer. It is testing time now and I am making a list of all the small adjustments that need to be made. I am looking forward to the Cabin Fever Expo in January 2020. Then I can show it at full height! Ceilings are in the way at home. Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Awesome update! Feels like a milestone has been reached!
That’s incredible what a piece of art you have there, must make you proud to accomplish such an intricate model. Great job. Steve
That is incredible! Would love to see some videos of it in action.
Rob
