I am posting these pictures for campmb. The scratch built brass bucket is outstanding! Ken zz Mike 5 by Ken Wheeler, on Flickr"/> zzMike 4 by Ken Wheeler, on Flickr"/> zzMike 3 by Ken Wheeler, on Flickr"/> zzMike 2 by Ken Wheeler, on Flickr"/> zzMike 1 by Ken Wheeler, on Flickr"/>
That bucket is a scale model?! Very nice!
That bucket is too much!!! I don't like people with that much skill. Incredible. Thanks CAW
Thanks once again to Ken for all your help and advice on this project along with Greg. Its great to have knowledgeable friends who are willing to help. I certainly used Ken's schooling on soldering. Thanks for your comments JTL and Q. This was a tough one! Mike
That's some really nice brass work. Looks real. Robert
Outstanding !
Excellent job.
Wow, just wow, that is outstanding work. Well done.
Mike:
Did you use a resistance soldering tool for your project? I am interested in hearing how well they work.
Robert
This is sensational - it's hard enough doing something like this with plastic, so it must be really tough in brass. Props & kudos on a job very nicely done.
Was the original model a CAT 5110?Looks really good.That bucket is awesome.
Thanks for all the nice words to all. No I didn't use resistance soldering. Mostly used a Dremel torch and some with a Dremel pencil torch. Since the wear parts and teeth had to be painted separately, I had to attach them after the bucket was painted. Under the advice from Greg, I used Zap to attach them. The lifting "eyes" on the teeth and corner guards are .55 mm brass rod drilled into them with a #76 drill bit in a pin vice. Went through quite a few bits. The teeth were cut out of 3/16 solid brass rod and shaped with a Dremel saw and finished with small files. Mike
Yes Modelmaniac, that is a 5110 that I converted to a 6015B about a year or more before CCM made theirs. There used to be pictures of on it on the Forum until Photo bucket disappeared them. Maybe some time I could post better pictures of it if you'd like. Mike
I have been thinking about changing my 5110,into a 6015.Seeing this has made up my mind,definitely will now.Would like to see some progress pics,although,there is no rush.The only thing is,I cannot produce any graphics,or lettering.
rlmc wrote:Mike:
Robert
Robert, I bought one a long time ago when they were about 1/2 the price or better. Works on the same principle as a welder. I use the tweezers for small parts and railings. It takes a while to get the heat settings right for the material. I suggest the on/off foot control, as you don't have enough hands to operate and hold the material. I never use the single rod at all. You still have to use a heat sink a lot of the time if you are adding pieces close to where you just soldered. I have been soldering with a pencil torch for years, especially for bigger pieces. Ken
