admin wrote:
2. Maybe harder. Does anyone know the weight of a Bucyrus 495 Track? I have a customer who wants to put a track on a flatbed as a load, but we both think they are way too heavy to make that realistic, even with a heavy flatbed trailer. IF we knew the weight of a track pad or a track section, we could then tell.
Hi Chuck....took from operators manual
Bucyrus International, Inc.
495HR Electric Mining Shovel
GENERAL ESTIMATED COMPONENT WEIGHTS
CAUTION: These are estimated weights only. Contact your Bucyrus
International service representative for the exact weight of
components on your specific machine before rigging and lifting.
LOWER WORKS
Quantity Weight Each
(U.S. Pounds)
Truck frame 1 191,430
Pintle bushing 1 280
Lower rail 9 570
Thrust rail 9 170
Propel brake adapter 2 370
Propel brake 2 650
Propel brake hub 2 60
Propel motor 2 4,500
Propel motor blower 2 210
Propel motor duct assembly 2 185
Propel brake guard 2 60
Coupling 2 130
Crawler belt (2 per machine) 2 244,000
Crawler link, 102 In. (47 per belt) 47 2,500
Crawler assembly~shipping 2 128,500Crawler structure 2 74,750
Propel gearcase 2 15,840
Front iIdler 2 5,800
Front idler shaft 2 1,150
Adjusting block 4 370
Load roller 8 2,020
Load roller shaft 8 550
Rear idler 2 3,800
Rear idler shaft 1 700
Drive tumbler 1 7,120
Drive shaft assembly 1 4,330
Drive shaft 1 3,370
Center pintle sleeve 1 9,100
Center pintle upper collar 1 380
Center pintle thrust washer 1 400
Center pintle lock nut assembly 1 1,470
Andrea
Life is for crazy people
Models For SaleFB
