When you announced the 72m boom, I was almost sure you would do this outside your house
My project for the Thanksgiving break: the 6-sheave hook block: Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Going to be a great looking block when finished. Excellent workmanship as usual.
Hook block done! I will make 2 more hook blocks, one with 3 sheaves and on with a single sheave. Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
This build is nothing short of incredible!
Absolutely beautiful!
Nice!
Auxiliary outriggers I spent the past couple of weeks fabricating the auxiliary outriggers. They are clearly needed for raising the more than 10’ of boom. Machining the pads: And it works! See the attached video. https://youtu.be/meyH0aCXr8UKerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Just incredible!
One of the best topics on here at the moment.
Looks awesome! We rally round the family, with a pocket full of shells.....
Kerst, you are soon to be in the paint booth.
What is this type of vice called?
Dex wrote:What is this type of vice called? I believe it is called an angle vice.
The next step is building a trailer for the counterweights and the boom. I choose a typical trailer used in the 70’s and 80’s for this purpose in Germany. It is a 4 axle Scheuerle trailer. I started a month ago and made some good progress. [IMG https://c1.staticflickr.com/1/957/40105725340_79ef300eab_b.jpg [/IMG] Kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Wow!
How is the crane progressing?
Brilliant.....
If you only do what you've always done, you will only get what you always got!
Paul R wrote:Wow!
Paul R The crane is basically done, just needs painting. Painting will be quite a job, because it means taking everything apart , a lot of sanding, priming and painting. then it will need to go back together again. It is a good summer job, because I can set up a spray-booth outside. kerst http://forums.dhsdiecast.com/default.aspx?g=posts&m=1096251
Enjoying the build Kerst. Look forward to your updates.
Trailer is looking great as well!
kerst wrote:Paul R wrote:Wow!
Paul R The crane is basically done, just needs painting. Painting will be quite a job, because it means taking everything apart , a lot of sanding, priming and painting. then it will need to go back together again. It is a good summer job, because I can set up a spray-booth outside. kerst Excellent! I can’t wait to see the finished product. Paul R
