![](/resource.ashx?u=92577) Rank: Advanced Member Groups: Member
Joined: 10/24/2006 Posts: 301 Location: Bunbury,W.Australia
Does any member have info, pics of this new model of mining excavator?
Rumour has it, that there may be a few prototype units on trial in Australia!
I think it is about 400 tonnes, with a bucket cap. of approx. 22cu m....
Any info would be appreciated.
Brian C
![](/resource.ashx?u=102887) Rank: Advanced Member Groups: Member
I would say that it is the new numbers for the 995.
//Niklas Eriksson
Niklas
This is a completely new model and is not the replacement for the R995.It fits in between the R9350 and R995. R9350:- 300-310 mt,{18 cu m} R9400:- 380-400 mt{22 cu m} These are approximate values/specs. R995:- 440-450 mt{26,5 cu m}
Regards Brian C
![](/resource.ashx?u=96719) Rank: Advanced Member Groups: Member
There is a little shift to finally fine tuning digger sizing to trucks and 380-400 ton is a perfect size for loading 200 ton trucks.
![](/resource.ashx?u=96287) Rank: Advanced Member Groups: Member
Gavin84w wrote:There is a little shift to finally fine tuning digger sizing to trucks and 380-400 ton is a perfect size for loading 200 ton trucks. I tend to think 1000 ton is perfect for 200 ton trucks.....lol. Got to load a couple 789s the other day with 38, two passes and gone. Brian
![](/resource.ashx?u=95504) Rank: Advanced Member Groups: Member
Greasemonkey wrote:Gavin84w wrote:There is a little shift to finally fine tuning digger sizing to trucks and 380-400 ton is a perfect size for loading 200 ton trucks. I tend to think 1000 ton is perfect for 200 ton trucks.....lol. Got to load a couple 789s the other day with 38, two passes and gone. Brian Ouch .. painfull. So had anyone got any piccys then?
![](/resource.ashx?u=99638) Rank: Advanced Member Groups: Member
All photos are from THIS provious DHS post. ![](http://i81.servimg.com/u/f81/11/01/17/28/dsc08813.jpg) ![](http://i81.servimg.com/u/f81/11/01/17/28/dsc08811.jpg) - Chris
For the mining enthusiasts:- Xstrata's Liddell Coal Operations in the Hunter Valley,NSW,Australia has taken delivery of the first R9400 in backhoe configuration,sporting a 22cu m bucket.It will compete in the same size-class as the Bucyrus RH170B,Komatsu PC 4000-6 and Hitachi EX 3600-6 hydraulic mining excavators.Assembly was completed on the 28 May this year. Another two R9400's will be delivered to the mine by the end of this year. The first R996B backhoe also went into service at the same time as the R9400, with a second unit scheduled for delivery by the end of 2010.Standard bucket capacity has been increased from 34 to 36cu m for the updated 'B' version. Regards Brian C
![](/resource.ashx?u=103764) Rank: Advanced Member Groups: Member
Those machines 2 ofmy frinds from school worked on they work for Liebherr at Mt Thorely.
![](/resource.ashx?u=95553) Rank: Advanced Member Groups: Member
Just saw this picture posted by 'Simram' over on LKW-Stefan. Looks good! ![](http://i29.servimg.com/u/f29/11/59/84/40/img_7411.jpg) Rowan. 1:25th scale CAT 375L excavator
Joined: 10/23/2008 Posts: 116 Location: launceston tasmania
